code 24 and no speedo
Old Sep 29, 2003 | 02:43 PM
Harley61's Avatar
Car: 90 RS / 89 IROC
Engine: 305 TBI / 305 TPI
Transmission: 700R4 / T5
Axle/Gears: 3.73 / 3.08
I was just driving home and I noticed the speedo was not working, shortly after that the ses light came on. I came home and checked the codes. I got a 24, I see in the book what it is, but how do I fix it?
Old Sep 29, 2003 | 06:09 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Re: code 24 and no speedo
To fix it, you need to fix the speedo (most likely the cable). This happened to me just last week on my '89 RS (305 TBI as well)when my speedo cable broke. The VSS reads off of the speedometer so if it's not working, neither is the VSS and it will activate the SES light.
Old Sep 29, 2003 | 06:14 PM
Harley61's Avatar
Until I can get it fixed, is it going to mess anything up? And did you have someone do it? How much should it cost to fix? Thanks!
Old Oct 2, 2003 | 03:29 PM
The only things you'll notice is that your car might run a little funky (mine did- but it occasionally does that anyway!) and your cruise control (if so equipped) will not work. I don't think that temporarily driving it with the speedo non-functional will damage anything. I replaced the speedo cable myself- it wasn't all that difficult, but you do have to get under the car. The factory cable insert had a plastic end (WTF??), the replacement cable insert has a metal end. I bought the entire cable (insert and housing) for $13.
Old Oct 2, 2003 | 03:33 PM
Harley61's Avatar
Update
Turns out I wasn't that lucky. The VSS was snapped in half! Replaced that and a broken rear trans mount and all is good again. It's a pain in the *** to drive in front of cops with no speedo...
Old Oct 7, 2003 | 10:34 AM
CamaroRS91x's Avatar
I feel ya dude....I have a code 24 no speedo...got a new VSS and noticed the drive gear in the trans is chipped....that will be a b*tch and until then I'm paranoid w/ the popo lol
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
