Carb Intake Options with EGR
Car: A Camaro
Engine: Weak
Transmission: Weaker
What are my options for a carb intake that have EGR??? So far the one's I've looked at don't have it except for a Weiland Team G which is single plane and it doesn't appear to be in the same place as stock. What are my options here?
Tony
Tony
Car: A Camaro
Engine: Weak
Wow, that was quick, thanks man.
Would you happen to know if it's in the stock location?
Also, is the brake booster line in the stock location?
If not, what would you recommend doing about this?
Tony
Tony
Car: 2002 Z28
the #3706 intake is a smog legal replacement for 87 LG4 engines. In sure the brake booster line and EGR are in the same position as the stock LG4 intake which im sure is very similar to the locations in the L03 intake.
Car: A Camaro
Engine: Weak
Don't ask...ok you did. Well the bolt that holds my TBI on the intake is in two pieces, one in my room and one is embedded in the intake and the extractor broke off in the threads....you had to remind me didn't you?
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
im sure you tryed to drill out the center of the bolt, huh?
how about drilling out the entire hole and having someone with a welder who has aluminium rods/wire fill the hole and redrill and tap it. or you could just put in a helicoil or a threaded or push in bushing and thread the ID of the bushing.
mdtoren
Aug 16, 2015 05:45 PM
