carb W/ECM timing
Old Nov 16, 2003 | 08:40 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
carb W/ECM timing
Is it possiable to change over to a carb and still have the ECM control the timing. I know you would need to ghetto rig the tps on the carb but what will happen if disconnect the injectors with the car running. Just wanted to know who is doing this because my new engine has a carb intake and it would be easy to go back and forth from carb to tbi.
Old Nov 17, 2003 | 05:16 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I have explained how to do this about a zillion times on this board yet this question keeps coming up. Try searching (button, upper right corner)
and no, you dont have to use the tps
Old Nov 17, 2003 | 06:41 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
I searched for about an hour and couldnt find what I needed. I will look at your post and see if I can find it that way.
theshackle
Sep 17, 2020 08:26 AM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
cstrobel65
Aug 15, 2015 10:19 AM
