loud pop whent i get on it
Old Nov 17, 2003 | 04:10 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
ok hears the deal. My truck was running ok till i did the header gasket on the drivers side. this is the side i am running my 02 sensor on. i had a big leak on #7 burnt the gasket all the way through. now wen i step into it it will pop some times to the point that the motor will die. any clue what is causing this. this is my list of specs.
1988 k2500. The truck has a holley tbi intake 670 cfm tbi comp cams extream energy cam with 206/212 i/e @ .050 dur and .434/.444 I/E lift. it also has full flowmaster cat back, hi flow cat and a set of gibson headers on the 350.
please help me
thank you
Old Nov 17, 2003 | 08:06 PM
c4boom's Avatar
Engine: l98 and lo5
up date runs good on start up after siting for 1.25 hours great responce and will lay ruber no prob.
there any thing else that i can give you that will help you help me
could it be the coil heatin up and die'n i had this hapen on a 89 rs once.
Old Nov 18, 2003 | 09:18 PM
JPrevost's Avatar
Car: 91 Red Sled
Replace your o2 sensor. Get any codes?
Old Nov 18, 2003 | 09:38 PM
c4boom's Avatar
Engine: l98 and lo5
ya i am going to do that any ways i think i may be going to a WBO2. but i found the problem the distributor clamp was loose and it slipped to about -12 (deg) tdc so i set it up about 5 (deg) advanced.
Old Nov 19, 2003 | 09:53 AM
JPrevost's Avatar
Car: 91 Red Sled
That'll do it . I had the same thing happen to me a couple times. After that happened I ruffed up the fingers on the clamp, no more slip.
RS Reaper
Oct 17, 2018 07:52 PM
loud91rs
Oct 5, 2015 10:05 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
Lmancha96
Sep 25, 2015 08:11 PM
