m.p.f.i. conversion
Old Dec 3, 2003 | 11:06 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
m.p.f.i. conversion
saw this on edelbrock's site:
http://www.edelbrock.com/automotive/mpfi_tbi_intro.html
as usual, they only make it for trucks and not fbodies.
summit sells it for around a grand. half the price of holley or accel setups. i've found one used .... can probably pick it up for 6-700.
what i find REALLY attractive about it is that it's smog legal. if you want to use f.a.s.t or accell dfi and remain smog legal, for example, you have to run a piggyback harness so the stock computer runs the smog control. that harness costs over 600.00 alone.
i wonder how they control 8 injectors with the stock computer?
i know the chip edelbrock provides is customized to the truck application. if it's the same type of chip, however, i wonder if the bin file could be modified like the stock ones?
does anyone know anything about these?
Old Dec 4, 2003 | 08:02 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I'm pretty sure they usea piggy back module to controle the extra injectors. You reuse your stock throttle body with this setup as well so your not really getting rid of the restriction just makeing it easyier to feed fuel. I doubt you can do much with the chip either, kinda a patch tegether job in my opinion.
Old Dec 4, 2003 | 09:50 AM
Berlinetta's Avatar
Its a PITA. The system WILL NOT work on our cars. Im not sure why, but thats what edelbrock claims. Do a search on this board. I had a few posts concerning this subject.
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
