Oil for the LO3...
Old Dec 6, 2003 | 05:07 AM
firebirdvert305's Avatar
Car: 1992 Firebird Convertible S/E 1 of 1263
Engine: 5.0 liter 305ci LO3
Transmission: 700R4 Automatic
Oil for the LO3...
Hey people i know GM recommends 10W30 for the LO3 engine....do u think valvoline VR-1 racing oil 20W50 would work fine?
Old Dec 6, 2003 | 10:54 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
My 1992 Camaro Owner's Manual and the Crank Cap says to use 5W-30.
Old Dec 6, 2003 | 04:03 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
If I put 5w30 in my car the valve guides leak, I've stuck with Mobil1 10w30 and the car runs fine with no leaks!
Old Dec 6, 2003 | 04:08 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
I run 20W50 in my car, never had any problems with it. Actually I run it in all 3 of my cars. Exxon Superflo 20w50.
Old Dec 6, 2003 | 04:31 PM
25THRSS's Avatar
I use 5w30 in my 92 as well and prolly wouldn't go any thicker than 10w30. My rule of thumb is to go as thin as you feel comfortable because thicker oils will just cause a loss in hp.
Old Dec 6, 2003 | 04:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I agree, i wouldnt go over 10w30. The thicker oil will jsut strain the oil pump and distributer gear and waste HP due to excess friction. The only thing i ever used the thick 'maple syrup' type oils in was my s-10. It was the only way i could build any oil pressure and keep it quiet.
Old Dec 6, 2003 | 06:06 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
use mobil 1 synthetic, i use 5w, but i doubt 10w would change awhole lot because in the end its still a synthetic
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
