Heads comming off...now what??
Old Dec 6, 2003 | 04:21 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
So...I grab my 416 heads tomorrow and will be dropping them off to my engine guy probably monday to have them cleaned up and ported etc etc.
Now...while i have the heads off is there anything you guys would recomend that I should take care of, or should I stick to the old "if it aint broke....dont fix it"???
Thanks,
Dave
Old Dec 7, 2003 | 12:23 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
someone....anyone????
Old Dec 7, 2003 | 12:42 AM
25THRSS's Avatar
I would go ahead and clean the tops of the pistons off, and it wouldn't hurt to check and make sure the lifters are in good shape. Can't be too careful.
Old Dec 7, 2003 | 12:44 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
thanks man........with the heads off...can I change the rings??? I am not sure etc...since I am the type of guy that learns as he goes etc and I havent really done this before (like everthing else I have done over the last couple of years)
Old Dec 7, 2003 | 12:48 AM
25THRSS's Avatar
nope, can't do anything with the rings with just the heads off. That would require a full rebuild. If I were you I would just do a little cleaning where it needs it, check everything to make sure it's in good shape, etc. Just basic maintanance. One piece of advice is to not use anything too abrasive on the pistons when cleaning.
Old Dec 7, 2003 | 12:51 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
thanks man.......
Old Dec 7, 2003 | 09:01 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Swap the cam with something a little more aggressive.
Like the Vortec cam on this page for ~$50.
Old Dec 7, 2003 | 09:47 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
If I didnt already go through a cam swap with it in the summer I would do it....I tossed in an L98 cam that I got cheep....did make a good difference but I still need to get into prom/chip burning etc.
Old Dec 7, 2003 | 10:49 AM
AJ_92RS's Avatar
Yea... the cam I showed you and the L98 cam are pretty similar.
evilstuie
Jan 9, 2020 08:29 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
project89
Sep 24, 2015 06:38 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
