max fuel pressure for TBI??
Old Dec 6, 2003 | 10:15 PM
89 305 Formula's Avatar
Whats the max fuel pressure a TBI can handle, my gas tank is leaking so im puttin a new one in and gonna put a higher flow fuel pump in.
Old Dec 6, 2003 | 11:01 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
The pump won't raise your pressure. If your going to keep an in-tank pump I'd go with a Walbro HP 255lph. You'll have to get an adjustable regulator or do the mod listed on the Ultimite TBI tech page to make the factory regulator adjustable to raise or lower your pressure. I'm not sure how high of pressure the TBI can stand.
Old Dec 7, 2003 | 07:49 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I had mine running at 25 psi for a little while after I installed the new spring. It didn't cure the knock problem though, so it's back to 22.5 psi, which I have ran for a long time. Only problem I have noticed with running higher pressures with tbi is fuel bouncing off the throttle blades at idle.
Old Dec 8, 2003 | 01:54 AM
JPrevost's Avatar
Car: 91 Red Sled
What injectors?
Old Dec 8, 2003 | 07:11 PM
Engine: LO3;383tpi
Delphi injectors.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
