aftermarket intake manifold
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: aftermarket intake manifold
Originally posted by joshwilson3
I have a 305 TBI, and I was thinking about later on, upgrading my intake manifold when I do my total tbi mods. I am looking for something good, but isn't too expensive, like maybe a 100-200 dollars. I don't wanna go too crazy cause it's just a 305.
I read on here that I should get a Carb intake manifold and put on a plate over the big hole for my tbi to site on. Is that better than just getting an intake manifold for a TBI? I guess Holley is a good brand, but what about edlebrock? Should I go with a carb or tbi manifold?
Car: A Camaro
Engine: Weak
Transmission: Weaker
The Edelbrock performer TBI is a direct bolt on, no problems at all there! The Edelbrock Performer Carb (3706) flows much better, but you're going to run into a few problems installing it, but nothing major.
shifty ??? why did holley develop theirs with a 2.00 inch bore? was that a 454 truck application? i assume edeldrock is a 1 11/16 due to it being designed/ used for f body replacement 305 cid. if so, is the intake port manifold runner to head intake port a better match with holley if we use a high perf head(like me) that has a larger port??? i was sold on edelbrock but now i am thinking may not flow enough as compared to holley ???
Car: '90 RS
Engine: 377 LSX
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
https://www.thirdgen.org/techbb2/sho...hreadid=214533
read that post it has a lot of interesting stuff about intakes. particularly single plane.
IMHO single planes are the way to go w/ TBI. I'll be swapping to one later this year, k, later 2004.
If you're going for easy replacement, edelbrock sounds good. if you're going for more power in the future and want carb, i'd suggest single plane, from all i've read its all good no bad.
-chuck
-chuck
ambainb
Apr 25, 2016 09:21 PM
