Dewey...question for ya
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Hey what is going on...I was reading in one of the other postings that you have the follwoing set-up.....
"using a weiand single plane (7525), with ported 416 casing heads, and a 670 TBI unit.....3:42 gears".
I am sort of if in the middle of putting together the same sort of combo and am interested in hearing what you run in the 1/4 and HP/TQ estimate if you have had it on the dyno.....
..thanks in advance & Cheers!!
Dave
Dave
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
that setup is not on yet. but it is in the garage, i still need some minor piecies (pushrods, gaskets, crap like that). basicly i bought another car, and that killed my money for a bit, but i really needed a daily driver, with all the mods that are going on with the camaro. i estimate that the combo will be 300hp. i am crossing my fingers on that, times SHOULD be in the 13's. i am not sure exactly when i will get this stuff on, but be assured everyone will know how it does on the dyno and at the track.
Car: 91 Z28 Vert
Transmission: TKO
Ah...sort of sound like me...my car is sitting in the garage just waiting for me to get my but into gear and start/finish things off....maybe I will start on a few things tonight.
The way my set up is "planned to go" is I have 7525....a set of 416's which are being shipped out to my buddies engine guy to have them worked over...and I have a new diff built almost ready to go into my car (I think they are actually 3:55's in there...but not 100% sure I will have to count the teeth again). I put an L98 cam in there at the begining of the summer but got frustrated with the new manifold & the EGR so I just tossed the old one back on just so I could drive it last summer....but for the most part I have almost the same set up as you sitting there in my garage....(geez a lot of good it is doing just sitting there eh...lol)....Ya when you do get things together let me knwo....I will be sure to do the same.
Hmmmm...I think I am actually going to go out and get waht I need to make myself my Aldl Cable....atleast taht will be a start... :-)
Dave
Dave
Car: 1990 Camaro RS
the aldl will be needed. it will need chip tuning.
since this thread is really a personal thread. i am going to get into a little bit of chip tuning here.
basicly, i put my headers that had been in the garage for months on last weekend (i had to do SOMETHING
this weekend i tuned the car. i knew that the headers would help, and would lean the engine out a bit, but i was not expecting to have to change my fueling as much as i did.
the initial run showed blms of 140+ above at and above 4k, it worked its way from 126 at 1k, up to that. a blm of 140 means that that i need 9.3% more fuel. i had blms in the 146 range at higher RPMs that is almost 12% more fuel. to maintaine a 14.7:1 AFR. that is pretty substancal change, for only headers. imagine how far off a car is, when you do cam/heads/intake and the jazz.
just some food for thought for everyone to concder when i talk about how important doing custom chips is.
) this weekend i tuned the car. i knew that the headers would help, and would lean the engine out a bit, but i was not expecting to have to change my fueling as much as i did.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 91 Z28 Vert
Transmission: TKO
as for the blm of 140 talk etc....I dont have a clue as to that sort of stuff so I cant really be of much help to ya guys...I am just learning about that chip/prom burning...but regardless keep me posted on your progress!
