TBI to TPI question
Old Jan 6, 2004 | 09:30 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
TBI to TPI question
I have a 1992 RS 305 TBI with 5 speed . I just purchased a TPI intake system from a 1991 Transam 350 with auto. My question is will the chip in the ECM work with my 305? Will I have to recalibrate the chip in any way? Thanks in advance.
Old Jan 6, 2004 | 09:35 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heh. theres alot more to it then that.
you're going to have to modify your harness or swap out to a TPI one.
and you need to get a diffrent ECM and "chip" alltogether.. a stock 305one would work fine though, so its not too hard.
if you didnt already know, you also will have to swap your fuel pump to a higher pressure TPI one.
Old Jan 6, 2004 | 10:41 AM
pwdbychevy's Avatar
I already have a TPI pump installed and the wiring harness and 7730 ECM comes with the TPI kit. I just don't know if the Eprom will have to be recalibrated to work with the 305 since the unit is out of a 350. Does it matter if I use 24lb injectors or 19 lbs? Does it matter if the unit is out of an auto and I have a 5 speed?
Old Jan 6, 2004 | 12:04 PM
Fredless's Avatar
Yes you need a 305 prom for a 5 speed and correctly calibrated for your Injector size. Did you read Anesthes' post a few down? Where all the fighting was? Read through the bull**** and you'll find some good info.
I just got back from the yard about 2 hours ago with my airbox, 730 ecm, 730 ecm connectors and 8 injector plugs.
here is the link:
https://www.thirdgen.org/techbb2/sho...38#post1616838
Old Jan 6, 2004 | 12:56 PM
pwdbychevy's Avatar
Thanks for the info.
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
