car runs bad
Old Jan 11, 2004 | 08:16 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
car runs bad
ok I have no ldea what the problem is but I have no power, the car has droped a second off the quarter, there is no codes and bad gas mileage, I've chang the 02 sensor what could be the problem?
Old Jan 14, 2004 | 07:56 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
could be alot of things.... do u have ne idea where to start?
Old Jan 15, 2004 | 07:32 AM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
im goin with plugs and wires as i just solved my prob doin that. course as the man said above it could be a number of things. try to desribe it better. just incase, dont think just because you just installed your plug wires that they couldnt be at fault. mine were only 4-5 months old, and two of them were junk.
Old Jan 15, 2004 | 07:36 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
check all the normal stuff, cap/rotor/plugs/wire, also check your fuel filter. watch the injectors and make sure they spray in a nice 'cone' shape. also, if you have a CAT if it is clogged up, it will cause major issues. you should also try a compresion test on all the cylinders. there are a whole host of things to look into. start with the cheap/free/easy ones, and work you way up.
Old Jan 15, 2004 | 08:48 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
exactly.... do all that these guys said first for free/cheap.... then work your way into spending money... makes sense to me
Old Jan 18, 2004 | 03:04 PM
Engine: 5.8
I put in new injectors and it runs beter now.
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
