injector size, i have part #
Old Jan 16, 2004 | 11:06 AM
Ronny's Avatar
17104288 ACR is from a 1995 2500 454 pickup 7.4 L. is this 80 or 85 lbs? i believe later years (after 1995) went to 90 lbs.
Old Jan 16, 2004 | 12:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: injector size, i have part #
I don't have anything on that number. Are there any color codes (two paint dabs on the top center piece)?
RBob.
Old Jan 16, 2004 | 01:18 PM
Ronny's Avatar
thanks for responding. the color i would say is purple? i checked with gmparts direct and they show last 4 numbersd as 0860 for 1995 chev pkup with 7.4L. this is a new unit supposedly for 1995 C2500 pickup 7.4L. i believe it was never installed as as clean as new.
Old Jan 16, 2004 | 01:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
As for the purple I have these two:
(1987-'89) 454-truck purple 90# 17111784
94 454 TBI purple/red 67.85#/hr
Some of the 454's ran higher then 13 psi fuel pressures.
HTH's,
RBob.
Old Jan 16, 2004 | 02:05 PM
Ronny's Avatar
thanks. it would appear the newer 454 at 68 lbs must have run higher pressure. interesting they do that. i have my 90's now at 9 lbs and was going to move to 11 lbs just to see the effect after i logged some wb02 in spring. i ran 12/1 at wot all the way to 6000rpms with 90 lbs at 9 lbs. so plenty fuel. now i have to decide if i should swap in my 90 lbs or leave at 68 and kick up FP a lot. which of those options sound better to you?
Old Jan 26, 2004 | 11:31 AM
Ronny's Avatar
i think my 7.4 L TB is 1994 OR 1995. I bet it is 68 lbs. i note holley runs 65-68 at 20 lbs. do you see an advantage of quality of spray by incr FP? it would appear GM decided to go smaller inj for some reason ? the 454 trucks may not need 90lbs if it runs higher FP.
toronto formula
Nov 10, 2015 06:17 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
knight72
Aug 10, 2015 09:32 PM
1nastygta
Aug 8, 2015 07:38 PM
