air cleaner for dual 454 TB
i see my TB pod is 2 & 3/4 inch over the lip of TB. first thought is purchase a standard 3 inch high 14 inch K & N. but i see a summit 2 and 3/4 inch (billet) thay may work with an xtra gasket used on horn if need be. i have a potential hood clearance issue on my 84 vette. 454 TB not yet installed. any suggestions? also is the vacuum thingie on TB throttle stop that is higher than horn an issue? i see some disclaimers that this air cleaner wont work with elec choke so is this a similar clearance issue as far as vac thingie? maybe trucks have a special air cleaner? same with linkage any issues there?
Car: check
Engine: check
Transmission: check
Re: air cleaner for dual 454 TB
On stock TBI vehicles there is a metal spacer ring between the top of the TBI and the aircleaner base. They come in all different heights. Cars have ones that are 3/4" or so, up to 2-3" for vans and trucks. Summit sells plastic ones, but they are thin and bend easily.
RBob.
Car: check
Engine: check
Transmission: check
if my TB pod is 2 and 2/4 inch from lip and the AC is 3 inch with flat base what is purpose of spacer? is there interferance with linkage ?
Since i used an AstroVan harness I went with that type of mount instead of changing the harness. The aircleaner I used was from a '80-something Caprice w/a quadrajet.
I do know that the spacer rings help with low speed throttle response. A lot of the stock TBI aircleaners have a ring extending upward about an 1-1/2 into the housing from the base.
RBob.
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
