Doing a complete tune up on 89 TBI, what do you guys suggest??
Old Feb 6, 2004 | 12:43 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I am tuning up my new 89 5 speed TBI. I just bought( I am the second owner) it and it's in pretty nice shape, but it seems like one of those cars that someone bought new, put gas in it and drove it. It just turned 58,000 miles and I can't tell if it's 58 or 158 since there is no 100,000 marker on the 89 odometer. Under the car is very clean, no oil from anywhere and the motor runs great. It has been sitting for a year or more but now it's my everyday driver so I want it in top shape.I am going to tune it up and want to make sure that I do everything I can. Here's a list so far:
Air Filter
Plugs Wires
PCV valve
Distributor Cap +Rotor
Oxygen sensor
Replace rusted muffler already with my old Flowmaster off the 90
Clutch, Pressure Plate, Throw out bearing
Change oil+Filter
Checked brakes--> fine
4-> 215 65 R15 tires
Adjusted the minimum idle cause someone screwed w/ it
Oh yeah, Check the timing ( 0 degrees is factory right? I don't have an emissions label)
If any one an think of anything else that I should check, please let me know. Thanks!
Old Feb 6, 2004 | 01:16 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
might want to do the fuel filter to while you doing things and some new spark plugs wont hurt either to go with those new wires. also one thing woud be to check the rear dif fluid if its bad lookin change it
Old Feb 6, 2004 | 01:35 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your list sounds good. I to would recomend a fule filter. I wouldn't mess with the clutch if it only has 58K miles on it. There shouldn't be a need to replace it. You should set your base timing anywhere from 4* to 6*. Some cars like more then others. The stock setting is 0 but these cars like a little more. You will get a few more ponies and a little better mileage as well. You may not have to change your PVC either. Just take it out and clean it up real well with some spray carb cleaner and make sure it rattles and there isn't any funk in it.
Old Feb 6, 2004 | 01:53 PM
GASGZLR's Avatar
I forgot to put the fuel filter!!
I do have a fuel filter, I just forgot to put it on the list. As far as the milage the shape of the motor and interior seem to lean towards 58,000, but the shape of the clutch leads towards 158,000. The only reason I am changing the clutch is cause when I put it in gear, and start to release the clutch and it won't grab until the pedal is almost all the way out!! Unless there is a way to adjust the clutch pedal, but I heard the hydraulic clutch is self adjusting. Any Input???????
Old Feb 6, 2004 | 02:10 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: I forgot to put the fuel filter!!
Yea that doesn't sound right. My clutch grabs when the pedal is about half way out. Do you have any records from the car. Like service intervals and such? Was there an oil change stick on thing in the upper left corner of the windshield. I am wondering how else we can determine the mileage of your car.
Old Feb 6, 2004 | 03:13 PM
GASGZLR's Avatar
Yeah there was.
As a matter of fact there was an oil change sticker on the window that I found this morning, it said 52,984. That kind of helps but not really cause the mechanic could have just gone off the milage from the odometer not knowing it had turned over once. I am hoping it's the correct milage though. Does my clutch sound worn to you? It grabs but not as fresh as it should.
Old Feb 7, 2004 | 09:19 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Wait untill carfax does one of the free promo things, then run it and it will tell you the actuall milage.
MustangBeater20
Oct 29, 2022 09:20 PM
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Street Lethal
Aug 14, 2015 08:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
