which TBI riser to get?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok im in a situation i cant decide which riser to get, the one from jegs or the one from turbocity
the one at jegs does not mention how tall it is, but it is aluminum , and including the install, its $82 bucks
the one at turbocity is 1/2" tall and made from delrin (prolly just a nice name for plastic from what it looks like) including the install, runs $58 bucks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: which TBI riser to get?
Car: '02 Z06
Engine: L33 5.7
would the injector risers raise the overall hieght and cause hood issues as well?
and i removed the black crap under my hood and because of that, the bolt on top of my air filter has more room to sit, so if jegs is 1" i think that would be fine
is the one you have from turbocity? i assume so cuz u mention its .5" .what do u mean by siameese runners?
and why do u think jegs is 1" tall? thanks!
Car: '90 RS
Engine: 377 LSX
Car: '90 RS
Engine: 377 LSX
i dont know what siameesed runners are!
Car: '02 Z06
Engine: L33 5.7
thanks i do understand what u mean. after i looked at turbo's and then at jegs, i see the difference, i would think jegs would be the way to go then because they are individual bores and its 1"
Car: '90 RS
Engine: 377 LSX
Car: '90 RS
Engine: 377 LSX
Originally posted by sbc350
This might help, It is a CFM spacer.
http://www.cfm-tech.com
Check em out.
Check em out.
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
do you have a particular need for the spacer? like shifty's? from what shifty has said to me about his, it seems like an overall waste of money unless u have to have it. and like he said you can get an LT1 cam for that price and see much more gain... or save for something else. i was also going to buy a spacer but shifty talked me out of it b/c of the less than substantial gains and problems that go along with it. just my 2 cents
Car: '02 Z06
Engine: L33 5.7
well thats cool i wish i could get more then one persons view on it, im pretty much set on buying it though
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Like everyone else here is saying, I wouldn't waste your money on it. Why are you so set on buying one of these? All you are going to get out of it is throttle linkage problems, you will notice NO power gain. So if you want to spend 60 bucks or whatever it costs to get some linkage problems then be my guest. If you're actually looking for a power increase save a little more money and do some exhaust work.
Car: '90 RS
Engine: 377 LSX
Originally posted by 50cent
dude, hot you are retarded that's not how you do it!
Car: '90 RS
Engine: 377 LSX
It is your money so you can do what you want with it. I only have experience with .5" so good lukc if you go with 1". I am not trying to be diffucult here but I know what works on these cars. Besides mine I have 2 buddies with LO3's. Two of those cars are built to the hills with every mod out there. Because of that I can tell you what adds power and what does not. I would put 50 bucks towards something that will actually add power and not headaches.
Here is a link that I posted about boring the edelbrock Intake. In some of the pics you can see my spacer. I milled that out as well just so I could use it unitl I got a flat base air cleaner.
https://www.thirdgen.org/techbb2/sho...ock+TBI+intake
Engine: 305 TBI
i already got my open element :P
BTW, in your sig, the 700R4 is a 4-speed trans not a 5. just FYI
Car: 1992 Camaro RS
Engine: 305 TBI
Car: '02 Z06
Engine: L33 5.7
ok well then where should i put 80 bucks laying in my pockt?
and for the transmission , i have the manual 5 speed, whats the code for it? just the T-5?
Car: '90 RS
Engine: 377 LSX
If I had a bone stock LO3 in front of me right now this is the order of mods I would do to it.
Tuneup
Subframes
Cat back
Cat
headers
Burning my own chips
Fuel pump
Heads, cam, intake, more tuning etc etc
Car: 1992 Camaro RS
Engine: 305 TBI
if i were u i'd put that 80 bucks in the bank or in a jar or somethin so u dont blow it on pointless stuff... like i often do. save it and keep adding to it until u save about 300 and get a nice set of headers from ACS or if u dont want coated from another place. or, spend around 100 bucks and get a cam and install it. but personally i would go with the headers first, and yes it's just a T-5
Car: '02 Z06
Engine: L33 5.7
ok super cool, well i just got my new job and my first check is gonna be about 400 bucks, i expect 50 to go to bills, and i assume 100-200 on registering my car. so i can say 200 spending cash
Ok Hot, you talk like you know everything, for once in your life stop actling like you know everything you dont need to save money and the gains are wack, you dont know anything you prolly dont even have a car
Car: '90 RS
Engine: 377 LSX
Car: '02 Z06
Engine: L33 5.7
https://www.thirdgen.org/techbb2/mem...e&userid=27787
click that link to add 50cent to your ignore llist
Car: 1992 Camaro RS
Engine: 305 TBI
50 i'm not gonna argue with you, look at my sig and you will see what cars i have/have had. if you dont believe me i will get pics of all 3 for you... and in your total 2 posts, what have you added that's useful? and for once in my life? how long have u known me 3 days? ok dude if u say so.
but back on topic, good luck with everything and keep us updated, take pics if you do your own installs. somebody else can always learn from stuff other people do.
keep us updated, and somebody will always have an answer for you if you need help!
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
TraviZ. take it for what its worth and dont repeat mistakes many of us have made, i for one have wasted money on, dumb things like platinum +4 spark plugs. and having stock heads rebuilt(could have purchased new aluminium or S/R TQ'rs)for what i invested in 'em. ASK the guys here what works....they know.
Car: 91 RS
TraviZ
Pretty much what Shifty said for mod's you could do.
If you want go power first replace all of the exhaust. Headers, cat then cat back.
Next heads and in my hindsite I would go with a set of 081 casting number TPI 305 heads. Search for previous posts on these heads as there is plenty of good info on them.
And to see how much air they can flow do a search for Tim Burgess. His 92Z 305 tpi 5 spd. kicks butt!! Don't be concerned that he is running tpi this will show that these heads will flow more than most tbi setups will ever need. When ported they flow well enough to run on a 350 TBI from the posts that I have read on testing them on a flow bench.
Hmm, interesting that bickering has started in a tbi spacer post. Nothing has changed.
IMO, spacers aren't worth it. Few people I knew got them and the common reaction was "uhhh, well, I guess its working"
Save the 80 bucks on gears, exhaust, pick up a lt1 cam off ebay for $40 and save it for later after you do the exhaust. You'll be dissapointed spending your money on it.
rs_z28_vert
Sep 30, 2015 09:47 PM
