TBI Engine for Towing
Car: 1991 Z28
Engine: 5.7
Transmission: A4
Okay, I want to build a 350 for towing. This is going into an 1988 Suburban 3/4 ton with 700r4. The gear will be 3.42. I am thinking about using a roller 350 with the LT1 camshaft. Also, I am planning to use my iron heads off my 1991 Z28 5.7. I am going to use the Summit shorty headers and an Edelbrock Performer intake with PAW TBI adaptor plate. Would the Ram Jet camshaft work better in this application? I am working on the chip burning with my 1991 Z28 so that would not be a problem. The exhaust would finish out with 3 inch pipe. What kind of torque numbers could I see with this motor? Thanks, BranZ
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: TBI Engine for Towing
EDIT:Let me know if you read that okay because for some reason my comp messed up and it posted but said zero replies on the main forum.
Car: 1991 Z28
Engine: 5.7
Transmission: A4
I would love to but I have that all too common cash flow issues. What is a good kit? The block is an 1988 IROC 5.7 roller. I do not think I can get away with just buying a crank? I really want to put my 454 in it but I need to do some research on the brackets to keep my current A/C compressor.
Car: '90 RS
Engine: 377 LSX
Ozz1967
Aug 16, 2015 10:23 PM
