Burnouts
Car: 91RS
Engine: 305tbi
Because you have an open rear, only one wheel gets power, I believe both wheels get power after you have traction?
A posi would spin both tires, or mabie prevent you from burning out at all depending on a number of factors, which is a good thing
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by ajmcmahon
ive read most the thread, and still cant really seem to understand why my trans am during a burn out, only the back right tire will spin ..... why is that exactly?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
New GTO smokie
Just for giggles, we took a new GTO and tested the theory that powerbraking is bad for the car. Only seems to have hurt the tires. This was all for scientific research, you understand
Troy
So Cal
Troy
So Cal
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
I had a little fun the other day. Took the lil LO3 out, powerbraked for a second, and let 'er rip! Lets just say that the burnout mark was over 200 feet, out of a LO3!!!!!!!!! All I have is an open air element and a catback, im so proud or her.
I'll get a pic once they get developed
Car: 91RS
Engine: 305tbi
My rear brakes are shot, and I made the mistake of letting my friend drive, he was flooring it with the brakes on for a good 2 seconds despite my screeming at him, and hitting him, now I have a strange sound back there
A certain person is going to be paying for whatever he broke.
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
Do all Camaro LO3 combos come with 3.08's? I got a LO3 in my 2 ton Caprice with 2.73's in the rear and can't do a brake torque for **** but it will spin em from a dead stop. I'm assuming its the weight and the fact that i have 2.73's. It will be easier with a 3.08 or 3.42 correct?
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
my lo3 has 2.73's and i've got no trouble spinning them (it). I think you could order it with anything between 2.73, and 3.42, but since it was made as an 'economy v8' most people got the economy rear hence all the 2.73's. Its possible that your caprice has a higher stall speed on the torque converter. the solution would be give it more gas. i cant imagine that it wouldnt spin.
-chuck
-chuck
Car: 91RS
Engine: 305tbi
Originally posted by Annihilator
Well i tried and it wont budge. I had it all the way to the floor and nothing.
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
tips
load it up with one foot on the brake then mash the gass then slowly let up on the brake
use oil on the rear tires or get in some sand in the road
last thing if neather of these work figure out what is wrong with car guz i have done some mean smoke shows with a geo metro and that is tbi and 1/5 the cubes
Car: 89 RS
Engine: lo3
there seriousally has to be something wrong with your car if you cant do a break stand. do you have discs?
-chuck
-chuck
Car: '90 RS
Engine: 377 LSX
This thread has lost all technical content so I have to shut er' down. Burnouts are pointless unless you are cleaning off your slicks. Even dirty slicks will provide enough grip for any 305 TBI therefore rendering a big burnout as an attept to achieve extreem macho-ness and nothing else.
Abubaca
Nov 5, 2016 12:22 PM
