Thinking about these heads...
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I just bought the Edlebrock Performer TBI intake and I also have access to some 305 TPI heads from a 1987 F-body. Would these heads bolt right up to the L03? Since they are from a 1987 305 I suppose they are center bolt. So can these heads bolt right up and function better (feel improvement) than the stock heads?
Car: 2002 Z28
yes, they will bolt right up and will flow better than the stock heads, if you have the time and money you should port them but only if you can do it yourself, i wouldnt put too much into the heads.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes those heads will work nicely. Some port work makes theose heads really good. Check out the "New to TBI" up top and read about head selesction in there. This gets asked a lot but you should find your answer in there. If you are still unsure please post up.
Brinkkl2000
Aug 4, 2018 08:29 AM
