Do L98 heads have similar exhaust ports as L03 heads?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Do L98 heads have similar exhaust ports as L03 heads?
Originally posted by 25THRSS
As far as the shape of the exhaust ports, are they similar?
Re: Re: Do L98 heads have similar exhaust ports as L03 heads?
Originally posted by ShiftyCapone
The shape is the same but that is it. The L98 heads are not swirl ports and do not have massivre amounts of material around the pushrod slots.
Car: '90 RS
Engine: 377 LSX
Re: Re: Re: Do L98 heads have similar exhaust ports as L03 heads?
yeap, I knew that, but I've never seen a pair of L98 heads up close. I was just wondering about the actual shape/size. Got any pics of stock L98 heads to compare with my L03 heads?
The aluminum L98 heads have D-ports as well, but the iron version look exactly the same as the 187 L03 heads (as mentioned above) but I'd say they more closely resemble a 081 head or 416, except with larger intake runners.
Car: '90 RS
Engine: 377 LSX
Originally posted by 3rdgenstm
Can the L98's be directly swapped to an L03? What else would have to change-- the exhaust manifolds?
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
you woudl want to mill the l98 heads some to use on a 305.. you would be loosing put much compression to amke it worth the swap. you could prob get awa with either 60 or 61 cc;s with a thin head gastet and be ok.. i have l98 heads at home i take a pic for you to sso the exhaust ports on them.
Car: ‘92 Z28
I can pick up a used L98 aluminum set for $130 is why I am asking. I have been told by some others that it isn't worth the swap (performance wise).
So I can use my stock ex manifolds on these as well until I get headers?
What thickness gasket or how much should be milled?? 15 thou? 30 thou?
Car: '00 Chevrolet Corvette
$130?!?! Yeah, I'd say that they would be worth that. The stock manifolds will work, but headers would be better (but you probably already know that). Technically, you won't have to mill the aluminum L98's, they've got 58cc combustion chambers. Since they're aluminum, however, you can run higher than stock compression. I'd shoot for somewhere between 52-55cc. Not sure how much off the bottom to get that, though.
Car: '90 RS
Engine: 377 LSX
For a 64cc head you can usually mill .020" and use a thin head gakset and come out right around 9.3:1. You can use the aluminum L98 heads that have 58cc chambers but you still want to mill them. You are going to want a little more compression with those heads. I would shoot for 10:1.
Car: ‘92 Z28
How much of a performance gain should I expect? I know they are quite a bit lighter and flow better, but from a HP standpoint? 10, 15, 20?
I am thinking I am going to jump on this and just want to make sure it is going to be worth the time.
Car: '90 RS
Engine: 377 LSX
Car: ‘92 Z28
Also, is it necessary to upgrade the cam? If so, other than the LT1 cam, what should I go with? Would the LT1 be the best for this combination? I am running the 163K mile original stocker.
Do these need to be '87 up? Well I guess that is a dumb question, but just for confirmation.
Car: '90 RS
Engine: 377 LSX
Car: 2002 Formula Firebird
Transmission: 4l60e
Thats what I thought. I was trying to buy a set of l98 heads off a guy in the classifieds. We had arrangements and everything. Asked him what the serial number is and he replies with 193's. I was angry considering 193's are lo5 swirl ports and I already have them...
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
14011083 350-300HP, Crate Motor, 64cc, 90º manifold bolt, hard seats
14011083 350, 87-up, 64cc, center bolt VC, 72º manifold bolt
check this out too:
http://chevyhiperformance.com/techar...98/index4.html
check this out too:
Car: 89 Firebird
Engine: L05 350 TBI
SBC Cast Iron L98 Center Bolt Valve Cover Head.
This is a cast iron cylinder head assembly used on 285 hp 350 engine. Includes 1.94” intake valves, 1.50” exhaust valves.
64cc chambers. The cast number for this head is P/N 14101083 or 14096217. This cylinder head has 1987 and later intake manifold bolt pattern. The center two bolts are at a 72° angle.
LT1Formula
20
Nov 14, 2015 12:02 AM
355tpipickup
Aug 25, 2015 12:54 AM
