Holley Pro-Jection Manifold?
Old Apr 3, 2004 | 10:58 AM
ron_firebird_91's Avatar
Car: 91 Firebird
Engine: 350 tbi
Ok so I bought a Holley Pro-Jection manifold and I was checking everything out today to make sure it would work out alright and there is no place for the vacum line for the power brake unit. So I am wondering what you guys did with yours?
Old Apr 4, 2004 | 06:32 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Holley Pro-Jection Manifold?
You can use another port on the intake for it. There should be another vacuum port to tap into. Carb intake guys do the same thing.
Old Apr 5, 2004 | 10:17 PM
Car: 91 Firebird
Engine: 350 tbi
I kind of didnt want to run all of the vaccum controls off of one port. Do you think it would be a bad idea to drill a hole in the side and tap it out to the size i need for the fitting?
Old Apr 6, 2004 | 07:16 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I think it is a bad idea only based on that it is easier, and if done right, cleaner looking just to T it off. I ran that same intake with the vacuum lines T'd, and never had any braking issues. I ran the same setup with the rpm airgap as well.
Old Apr 8, 2004 | 11:03 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
On my RPM I use a T and my friend who has the pro-jection also Ts it. I wouldnt worry about tapping it.
Old Apr 8, 2004 | 11:39 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
as long as you didnt do that in a stupid place, it wouldnt be a problem.
ive done it before.. no ill effects.
cowansauto
Apr 3, 2025 12:51 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
