Poormans Open element
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
I was under the hood useing some degreser and i realized what if i took the air duct off and left the bare inlet. i think it would be like an open element for free! lol i know it came to me when seeing old chevy air cleaner asymblies and i thought well it would work but the aera that the air would be comeing in though would be a little less restrictive but then all you donig is sucknig in gobs of hot air. so what do you think this would do? would it have positive or negitive effects?
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
I dont think it matters since the door (look inside you'l see a little door) is always open when its warm.....unless you removed the little door. Or you can just flip the top of the air cleaner cover over and you'll have about 1 extra inch all around.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It still wounld't be an open element. It would have to be open on all sides. Flow will be about the same it you take the duct off.
yeah thats what i though it was jsut a stupid little idea. while im here id like to ask you a quetion shift when i get ready to drop the 327 in with a open element (say a k&n extreme lid) will i need to buy a cowl or just barley clean or would it be better to buy a smaller shorter air fliter?
Car: '90 RS
Engine: 377 LSX
Car: '91 Firebird
Engine: TBI 305
Transmission: TH700
That solves half the problem, but you're still restricted by that (*%)(ing spacer ring. It's even more restrictive than that little inlet.
And open elements are really cheep. especially the flat-bottom ones
If you just want to maintain the stock appearance, you can probably find a suitable donor for a better air cleaner in the junkyard....
I should go have a look-see...
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
