What did yall use to heat up your TDS FPR??
Old Apr 9, 2004 | 03:30 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
OK, as far as I understand it, break off the security pin, and then heat up the spring housing so as to loosen the thread lock, but what did yall use to heat it up?
Also, when I was on the phone w/ Lon, he suggested that I loosen the spring housing before making adjustments on the torx screw. Do the rest of yall do this as well?
Old Apr 9, 2004 | 06:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I didn't have to heat up mine to get it to turn. It was hard but I pushed in the torx driver very hard and slowly turned it. It eventally came loose. You may want to try and turn it in both directions. After you excersise it a bit it will screw freely.
Old Apr 9, 2004 | 07:48 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I had to heat mine to soften the loctite on the set screw. I took the housing off so I wouldnt damage anything with the heat. I used a propane torch and carefully heated it while holding it in a vise. 250*-300* is enough.
Good luck.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
Lmancha96
Sep 25, 2015 08:11 PM
