Closed Loop...
Old Apr 13, 2004 | 11:18 AM
SLC_Chevelle's Avatar
Closed Loop...
I have a 95 7.4 I transplanted into a camaro and I was wondering when does it goes into closed loop mode and if it ever runs closed loop at idle? My O2 value barely jumps from .45x to .47x at idle and revving it. Is this normal? On my 97 it has huges swings from .0xx to .7xx at idle.
Also, I have the CATS tuner program and there are a couple of option that has "open throttle" and "closed throttle" screens, what exactly is the difference? Is closed throttle mean idle or when you let off the gas?
Thanks,
Lee
Old Apr 13, 2004 | 11:29 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
in closed loop the o2 values should swing like you described, when i run open loop in my car, that is when the o2 values remain in the .45 range.
you might check to see what the settings for closed loop enable are set to in your bin. there are also a few BLM enable values , you might check those out too.
depending on your datalogger you should be able to check the closed-loop flag, to see if you are in closed-loop or not.
Old Apr 13, 2004 | 12:13 PM
The read out shows open loop, that's why I was wondering if/when it goes closed at idle.
The CATS software does not show me anything as to when/how the closed loop is enabled. I was hoping it gave me access to more information but it doesnt.
Lee
Old Apr 13, 2004 | 02:38 PM
Dewey316's Avatar
Car: 1990 Camaro RS
you would have to look at the constants in the bin, there is a min closed loop temp setting, i had a problem when i put a 160* t-stat in, my car never got warm enough for it to enter closed-loop, i lowered my CL enable temp to 140* , problem solved.
Old Apr 13, 2004 | 03:14 PM
Ronny's Avatar
mine goes closed loop at about 157 deg with a 180 therm. i believe open loop idle allows you to command A/F ratio at idle outside of the choke effect. i dont think there is any issue with open loop idle all the time as long as settings are appropriate for your engine.. i guess with some of the larger cams running open loop is considered.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
