Head swap on L03..ET Change??
Old Apr 27, 2004 | 09:04 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Just for fun...as I am in the middle of porting a set of 416's for use on my L03....what do you guys think I am going to gain once these things are tossed on the car.
Currently this is what is on the car....stock engine, l98 cam, pullies/wires...etc...yadda yadda yadda. Headers and exhaust, stock open diff and is an Auto. Car runs 15.6...I think she has more...but I dont drive it enough to say for sure.
So after the ported/polished 416's, an intake and some LCA's... what do you guys think that will knock off my et???
Any ideas....this is just for fun...what do you guys think I will see at the track once I get these things on there.
Thanks,
Dave
Old Apr 27, 2004 | 09:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will most likely run slower unless you get into chip burning. With a properly burnt chip you could see low 14's.
Old Apr 27, 2004 | 09:25 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
ya thats cool....I thought I might run a little slower...it just gives me more incentive to get into chip burning I guess....well atleast I have that started I have the cable made and I know it works :-)
Old Apr 27, 2004 | 09:35 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Go ahead with the head swap but be prepared for the ar to run like poo. You will be so happy when your chip burning skills rip seconds off your et's.
Old Apr 27, 2004 | 09:41 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Tanager,
The set up you have is almost exactly what I have. Including the 416's and the L98 cam. After the install I ran a 17.6 and then a 17.1 after some chip tuning. It was then that I discoverd the rocker arms were loose. I used the old bolts on them. Make sure you get new ones and don't repeat my mistake. The old ones would not keep them tight. After the rocker arms where tightened I ran a 16.4. Still need to do some tuning but it really feels good. I know the power is there just have to unleash it with some good tuning.
Here's a few pics for ya:
the 416 heads.
Old Apr 27, 2004 | 09:47 PM
azvolfan's Avatar
Tanager,
The set up you are doing is almost identical to what I just did to my '92 RS. Right down to the 416 heads and L98 cam. I ran a 17.6 after the install but went to a 16.4 after some tuning and tightening the rocker arms. Make sure you use new bolts for the rocker arms. Don't repeat my mistake. The old one would not stay tight.
More tuning is in order for me. It feels great and I know the power is there, jsut have to unleash it.
Here is some pics for ya.
Old Apr 27, 2004 | 09:48 PM
azvolfan's Avatar
Ceramic coated Hooker Super Comp 2055's
Old Apr 27, 2004 | 09:49 PM
azvolfan's Avatar
The finished product.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
jharrison5
Aug 19, 2015 05:53 PM
