Is it possible to adjust idle manually??
Old Apr 29, 2004 | 03:00 PM
Sgt.D's92RS's Avatar
Car: 92 RS
Engine: 305 V8 numerous Mods:
Transmission: Auto+shift Kit 3.73 gears
Ok first let me clarify that I am not a moterhead so this might be a dumb question. Is it possible to adjust your idle on a 305 with a TBI manually or does it have to be by the computer. Under the hood there is a label that says do not adjust idle it will adjust manually!!!!
Old Apr 29, 2004 | 05:10 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There are a few tricks to fool the computer but you can only tinker with it by playing with your IAC and TPS. Does your cars idel not suite you? The stock tachs are notoriously off by the way.
Old May 4, 2004 | 07:51 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you cannot adjust the idle, the computer is going to always try to find its commanded idle speed, if you start burning you own chips, you can change the commanded idle speeds. if you were to adjust it manualy to the point where you change the actualy speed, you are going to either be running the IAC full open, or full closed.
now, with that out of the way, to adjust the idle, you need to take a punch and open up access to the torx screw in the TBI that controls how far the throttle blades are open.
Old May 4, 2004 | 09:55 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
The location of the plug that is hiding the idel adjustment screw is on the front right hand side of the TBI unit (if you are standing in front of your car looking into the engine compartment) Its about 3/8" big, just take a punch to one side and pound it in the the opposite side of the circlular pulg, its a fairly thin plug so it easy to get out, and then clockwise turning the idle screw increased idle and counterclockwise decreases idle.
Old May 4, 2004 | 01:50 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
for instance my cars tach says its idling at 2000rpms, which is whooy- if it was going that fast it would be making more noise then it does.
specialized
Jun 18, 2022 09:26 AM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 21, 2015 07:20 PM
perZ
Aug 15, 2015 01:17 PM
