idle on a 90rs
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Chance are your tach is just off and your car is idleing fine. Does it hesitate or act like it needs a boost. The idle is set in the prom but you can do a few tweaks to raise it if you have to.
Car: 2002 Z28
there is a article in the tech article section about setting your idle. At the front right side of the TBI there is a hole with a cap pressed inside, get a screwdriver and pop out this cap, it will allow you to adjust the idle screw with a T-25 torx bit.
