Hood Clearance Question
Old May 19, 2004 | 11:27 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I am installing the Edelbrock Performer TBI w/EGR intake on my L03 in the 92RS. I am also installing a non-drop base 14x3 open element. Will I have hood clearance issues with my stock RS hood?
Old May 19, 2004 | 11:52 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Hood Clearance Question
Nope. Everything will fit fine. The intake is about .25" taller than stock and you still have more room for a taller open element. I run this intake with a 14x3 element and a .5" spacer and my hood shuts no problem.
Old May 20, 2004 | 11:39 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Thanks man! Now, the project begins! Any tips for installation?
Old May 20, 2004 | 11:42 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Get a can of 'The Right Stuff' don't mess with trying to sue the front/rear gaskets, or using RTV.
Old May 20, 2004 | 04:30 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
Thats the great thing about the Edelbrock Performer TBI, it pretty much bolts right on. On mine I had to drill and tap a hole for the air conditioner brace or something. Read all the instructions first before you start.
Good luck with your installation. Dave
Old May 20, 2004 | 08:21 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup I had to do the same thing. I did however run it without that bolt for about a year. But then I sheared the top bolt off into the head on the acessory bracket. Woops. It is a good idea to have that tapped before you put it on. The only other thing I had to do was bend the fuel lines a bit with a pair of channel locks.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
