125 bucks to summitt...
Old May 24, 2004 | 04:43 PM
JDizzle's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
for my bday yesterday my parents got me 125 dollar gift certificate to summitt and i was just wondering if yall had any suggestions on what to buy, i really only wanna spend that 125 and not too much more of my own money. i looked for a shift kit but i havent found one for the 700R4 if anyone could find the part # thatd be cool cuz apparently im inept. anyways i was thinking about a shift kit or maybe a fuel pump or possibly a high flow cat cuz my current one is gutted and im gonna need to pass inspection (legally), about replacing the cat, if i buy a universal should it just bolt on in or am i gonna have to possibly have some pipe welded in too? any ideas would be great thanks, the mods i have are in my sig.
Old May 24, 2004 | 08:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would suggest saving it for now and when you get a little more go with tsome headers. However, I know that money will burn a hole in your pocket. I would maybe try to muster up a little more money and get a set of sub frame connectors. If not look into the TBI strut tower brace.
Old May 24, 2004 | 09:52 PM
JDizzle's Avatar
Engine: 305 TBI
i found the price for the B&M kit and its like 35 bucks, is it worth buying?
Old May 24, 2004 | 09:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea. Your shifts will be firmer. Check out the Drivetrian board for some more opinions on it. you may want to try a few searches first.
Old May 24, 2004 | 11:33 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
i like mine, just make sure you adjust your TV cable right after you put it in. Breaks the back end loose at like 40-45 w/ my 2.73's. Its a bitch to install though, dont let them tell you under an hour, everyone i've talked to says 11-12 hours, and it took me 12.5 by the time i had everything cleanedup. If you do go that route though, make sure you get a drain plug kit and a new filter. You'll be up to about $50 if you factor new fluid into that also.
-chuck
cmichael
Nov 26, 2015 09:53 PM
BrianI
Oct 3, 2015 12:57 PM
Giocio
Oct 1, 2015 12:20 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
Damon
Sep 26, 2015 04:29 PM
