Air/Fuel mixture Gauge...
Car: 89 Camaro RS
Engine: LO3
Do you guys know what color is the wire where the gauge hooks up?
-89 Camaro RS
-Autometer Phantom A/F mix gauge
-89 Camaro RS
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by alli89
Autometer phantom series
I've got the Positive and negative part but I can't get which wire to tap in my 02 harness
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
so to hook it up you just splice it to the wire that goes between the O2 sensor and the O2 sensor hookup?
Car: '90 RS
Engine: 377 LSX
Car: '90 RS
Engine: 377 LSX
what color is that wire on a camaro lo3
Car: 89 Camaro RS
Engine: LO3
I tried hooking it up to the purple wire that comes from the o2 harness but now i get a very weird reading
4 bars telling me that is runinng lean
1 bar telling me that is running rich
Can any one help locate which wire i need to splice
what color where it is and so on
Car: '90 RS
Engine: 377 LSX
Car: 89 Camaro RS
Engine: LO3
I've seen the same guage in another car and i worked completely different. It went side while the car was at crusing speed
Are you saying this is normal on tbi camaros?
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if the car you hooked it up to before was carbed, you will get entirely diffrent readings.
the FI system works on a swinging 02 value. when the computer is adjusting the A/F it will not settle at .450mv's it will flucuate, it is designed to do this for emmisions, rich/lean/rich/lean/rich/lean, it does this to allow the cat. to work properly.
at WOT, you should be going for 850mv's that will be fairly rich on that gauge, but it is not very accurate, these stock o2 sensors are really only accruate in the 14.7:1 range, which you will only see while the car is cold, once it warms up and reaches closed loop, it will jump around.
theshackle
Sep 17, 2020 08:26 AM
