Cowl induction hoods, smell gas fumes?
Car: 1994 Z28
Engine: 5.7 LT1
Hello,
Anyone with TBI open element ever smell the gas fumes while running you AC?
A friend of mine currently not a member of the boards, bought a cowl hood to go with his open element for his TBI and he complains of fuel/gas fumes smell while running the A/C.
Is this common?
Thanks,
FYI- He'll be a registered member as soon as he gets an ISP.
Is this common?
Thanks,
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It may be due to the fumes blowing back through the opening in the cowl into the HVAC air opening which is located below the screen at the base of the windshield.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by JR92z28
That's what I figured, but is this common?
Car: 92RS
Engine: 357
I been smelling gas too but with my AC/heater on vent. In fact I keep stoping and poping the hood looking for a leak. Its way worse when its hot . I only smell it sometimes at a stop sign or when I pull into the garage.
P.S. ya I got a cowl hood also.
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I had that problem when I first put my open element on. It ended up just needing a different/better valve cover breather. Got a 2.5in K&N valve cover breather with the right size hole to fit the valve cover and a gromet. Problem solved for me anyway.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
