SMOG and EGR
Old Jun 10, 2004 | 05:44 PM
NEEDforSPEED's Avatar
SMOG and EGR
i dont need to be leagil, so i have already takeing off some things
what do i need in terms of keep it runnig right...
can i take off the EGR... with out missing up the computer and haveing it run ****ty... or will i run the risk of detonation....
any help, cuz im takeing it all off as we speak.... dont need to find out i needed something i tossed out
Old Jun 10, 2004 | 06:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The EGR is actually a good thing. It helps emmisons at part throttle and keeps combustion temps down as well as fuel mileage up. It shuts off at WOT so there is not really a need to get rid of it. You need to program it out if the chip or you will throw a code.
Old Jun 10, 2004 | 06:15 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'll second that. Keep it.
Old Jun 10, 2004 | 08:18 PM
25THRSS's Avatar
I got rid of mine with a billet aluminum block off plate from custom billet works. I'm not a huge fan of carbon build up on the inside of my intake and ports. Also removed a lot of crap from under the hood. I say remove it, but you must also delete it from the chip or it could cause detonation problems. Also, if you have a good flowing exhaust, the lack of backpressure can cause problems with the egr valve which I didn't like either.
http://www.custombilletworks.com/
Old Jun 10, 2004 | 08:29 PM
how so?
Old Jun 10, 2004 | 09:36 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
how so?
It can cause it to not open or close right. That can be fixed with a negative pressure EGR valve found on some older trucks. It is very rare though. I never had problems and neith did my buddy. That doesn't mean it can't happen though.
jaridjohn
Oct 5, 2015 07:01 AM
