Another TBI Secrete "FOUND!"
Old Jun 13, 2004 | 11:54 AM
NEEDforSPEED's Avatar
well, as most of you know iv been hard at work on my motor
anyways after porting my TBI unit i have found something that wont help it flow as much it could, and i dunno if anyone else has seen this or not... but this is for you guys that still run the stock air cleaner assemblie and or who has converted to a duel snorkel set up
i would recommend do what i just did!
i grind down the lip that comes up it looked like it wouldn't suck more then half an inch around when the lid is on...
heres some pics
Old Jun 13, 2004 | 12:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Any before pics? Can't say I have ever heard of anyone doing this. Your air flow gains will be minimal at most and your engine will be able to get enough air even without that mod. However, one you add heads and cam it could play into effect. That is however, if you are absoutely determined to use the stock air cleaner assembly.
Old Jun 13, 2004 | 01:24 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
I found the stock air cleaner to be ugly and useless, from the info that ive gathered throughout the internet, that stock cleaner assembly is insufficient even for a 4cyl engine much less a V8. I had CAI setup for my car theres a pic of it in "TBI engine shots" thread, i abandoned that idea and went back to an OE, for one i'll be adding an 427StingRay scoop so ill be getting the same effect of incoming air from the front and i can still get air from the base of the windshield which is said to be a HI air pressure point im sure the car will never see hi-speeds but what the heck.
Old Jun 13, 2004 | 01:26 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
There is an air silencer ring on the stock air cleaner that I know of and many people have removed it. I believe you found that.
Old Jun 13, 2004 | 01:50 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
Yeah, when I built my CAI, I tried beating it down. As I was beating it tho (that sounds dirty :S), all the welds popped and it popped out and cut my arm. Doh!
Old Jun 13, 2004 | 11:02 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
uh, yeah, not much of a secret, we were removing that back in 1998 when there was maybe two tbi guys on thirdgen..
that was before we knew any better though, anyone with any sense would have gone to an open element
Old Jun 14, 2004 | 01:07 AM
hellraiser319's Avatar
yeah all you did was grind down the silencer ring. it would have been a lil easier and alot less time consuming to take a narrow chisel or standard screw driver and popped the tack welds and just pulled it out. id recommend you still do that cuz eventhough you did grind it down pretty good there is still a lil lip there which could rob some airflow, how lil in amount it can be. otherwise good find. helped out mine a lil when i took mine out too.
btw: if you do decide to remove the rest of it, make sure you dont bend out the bottom of the cleaner too much and make sure there arent holes in the base from ripping up the welds. i wrapped some electric tape around mine about 10 times to make sure it was sealed
Old Jun 14, 2004 | 02:33 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
were you there? no, we cut it off because trying to break off the tack welds would screw up the housing.
Doesnt matter anyways, that aircleaner is useless, like talking about modifying a 77 Mustang II
Old Jun 14, 2004 | 03:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
here, want somthing better, and fun to screw around with?
try to figure out how to fit the "soup bowl" over the TBI under our hoods.
This is the soup bowl, what Hypertech calls a Power Charger. Since TBI units feed from the side, this radius bowl improves airflow into the throttle-body with its gentler radius. Just the addition of the Power Charger after the headers and the Hypertech chip was worth 8 lb-ft of torque and 8 hp! Amazing.
Old Jun 14, 2004 | 06:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
In back to back testing, of a 2.25", 3", and 4" K+Ns on my 355 TBI'd F Body with my own prom, 90#/hr injectors, etc. etc, the car was actually fastest with the 2.25 element. I wound up building a same kind of dam like the stocker but used the 4" element. And the car was quickest with the 1.75" ridge and using the 4" air filter.
It's easy to assume a modification might work, but it takes actual testing to evaluate modifications. And what works on one car might not work on another.
Old Jun 14, 2004 | 06:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I had a Harwood cowl induction hood, so I had room for a 4" open element, and actually used bowls from KMart to make bits like that at one time.
Eventually I wound up just making what looked like a Vette Carb Flame Arrester, with a brass ring on the bottom, and then 1/4 screen soldered onto that rested against the air filter lid to hold it in place.
MustangBeater20
Oct 29, 2022 09:20 PM
z28addict8490
Sep 5, 2015 03:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
