TBI Nitrous
Old Jun 14, 2004 | 11:38 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
TBI Nitrous
Hey is anyone cares I just put a Nitrous Works TBI nitrous kit on my RS, i have a 350 TBI engine in it, and it works great, i only have to 50 HP jets in right now but it flies, the directions that came with the kit really sucked so you have to know a little bit about you engine and TBI before you install and have to make sure that you are comfortable do little alterations to you TBI, I'll get some pics sometime but all it is , is 2 selinoids mounted on the drivers side valve cover, i just dont use it under 2000 RPM's and so far i havent kicked it in under 4th gear, let me know if anyone has any remarks or ?'s
Old Jun 14, 2004 | 11:49 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Sounds really cool. It will be neat to see some of those pics. What kind of fuel pressure are you running?
Old Jun 14, 2004 | 11:57 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
not sure what my fuel pressure is, i have a JET adjustable fuel pressure regulator but i should get either a fuel pressure gauge or tester, does anyone know a good AC Delco spark plug that runs a little bit cooler than stock for N20 but i can still drive it fine when im not using N20?
Old Jun 14, 2004 | 08:49 PM
25THRSS's Avatar
Sweet, pics would rule. Why did you choose the Nitrous Works kit over the NOS or NX kit? I personally prefer the NOS kit myself, but I'll go into that later.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
