Fuel Smell
Old Jun 20, 2004 | 05:05 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Fuel Smell
Hey All..
Well I finally got my car running right...sorta. I replaced the EGR Valve and selonoid. Took the car out for a test and YAY!! no EGR or SES codes coming up. Now I rebooted the ECM and took the car for a good run from here to huntsville which is about 180 Kilometers away and back. I noticed that when I came back that there is still a strong smell of gas in my exhaust which means my car is still running rich.
What else should I do/change to have the car lean out so its not running rich. Could this be because I added mods without chip burning?
Any advice would be greatly apreciated.
thanks
Old Jun 20, 2004 | 07:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What mods do you have besides the ones in your sig? usualy these cars will run a bit rich when you have the stock tune and every bolt on. My car ran rich with my intake and full exhaust. Do you have a cat? Have you backed off the fuel pressure a bit.
Old Jun 20, 2004 | 10:38 PM
ThraxXx's Avatar
I have a full magnaflow exhaust. Magnaflow cat and muffler and a 2.5" pipe going from headers back. I forgot to mention that I replaced the O2 as well.
I am not sure how to back off the fuel preasure.
Old Jun 21, 2004 | 08:41 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Check out the ultimate TBI mods for that. Also, Bosch 02's can make your car run slightly rich.
Old Jun 22, 2004 | 12:07 AM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
check your evap canister, i had that problem a while back.
chazman
Aug 28, 2018 03:25 PM
dyeager535
Aug 28, 2015 08:10 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
chazman
Aug 22, 2015 02:01 PM
