for those with the edelbrock performer intake manifold
Old Jun 20, 2004 | 10:00 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
You may have heard i recently purchased mine.. but i got setback do to unexpected financial problems, so i havnt had the time to purhcase all the gaskets and stuff to do a proper job.
but i did notice.. either i lost them or i never got them, but i didnt get the sheet with my intake manifold that has the torque specs and stuff on it.
any of you with thi manifold happen to have this paper ? i would like a copy of it.
i checked the edelbrock website and they dont have the papers their online format
Old Jun 21, 2004 | 02:31 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I just installed one on my RS and if you are talking about the torque of the intake bolts, the sheet says to torque them all to 25ft-lbs. But you MUST torque them in a special sequence or the mainfold will not seat right and can cause leaks. I don't have a scanner so I don't know if I can help you out with the sheet. Good Luck!
Old Jun 21, 2004 | 02:58 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks for the torque.. anyway you can tell the sequence it goes on?
Old Jun 21, 2004 | 08:28 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
just go like 10 lb ft first pas than go 20 than go 25. I do one on each side criss crossing. I am not sure of the exact sequence but a haynes manual will tell you. Any intake you buy can be torqued to 15 to 30 ft lbs. I go 25 and have never had leaks.
Old Jun 22, 2004 | 07:58 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
you want to set the final torque on the bolts toward the center first. Then criss-cross like Shifty said, working your way outwards.
beastin91rs
Oct 9, 2015 07:38 AM
earlpote
Aug 28, 2015 10:42 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
