what would come next?
Old Jun 23, 2004 | 08:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
after everything from K&N open air element, edelbrock performer intake manifold, world torquer heads, camshaft with 1.6rockers, and camshaft with these specs:
Lift: .487''/.495''
Duration: 264°/270°
and of coarse 1 5/8" headers, 3" Y-pipe and 3"cutout valve.
what comes next? a larger TB? or maybe just bigger injectors?
Old Jun 23, 2004 | 08:13 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Chip burning. Then when you get it dialed in look into a larger TBI unit and then prom tune again. You will need suspension to.
Old Jun 23, 2004 | 09:36 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
i agree from what i have seen there is no way that thing is running anywhere near where it should with the stock tune. you might also consider the 454 TB and injectors or the holley unit... but definetly tuning. also what gears do you i have? tuning first but i would consider gears after that.
Old Jun 24, 2004 | 01:17 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks.
i will prolly have a base chip burned from tbichips.com
im about too order the rest of my exhaust setup, then next month comes heads and cam. so im trying to figure this all out what comes next intake is already done. i forgot about gears i need some 3.73's
Old Jun 24, 2004 | 10:22 AM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
i just thought of something, but its a valid mod, have you thought of going with a Pro 5.0 shifter or something similar? i know a few people with one and all of them like it. and good luck with the tuning with TBIchips if i were you i would get the heads and cam first and then get the chip tuned, it will be "easier" that way imho
Old Jun 24, 2004 | 10:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you are going to try to do it yourself, it is much easier to learn on a stock motor.
Old Jun 24, 2004 | 10:38 AM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
hes having the chip tuned by tbichips
