Taking off IAC
Old Jul 6, 2004 | 12:41 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Taking off IAC
This might be a stupid question, but oh well...I recently rebuilt my TBI but did not remove the IAC. That is the only part I did not replace on the TBI. Anyway, I am regretting not removing it and cleaning it separately then installing it with a new gasket. Do you think it would be a good idea to just remove it while the TBI is still attached to the intake manifold? OR do you think I should go through the process of taking the TBI back off meaning I would have to install a new gasket to the manifold??? I cleaned the hell out of the TBI with carb cleaner and got the underside of the IAC pretty good too...what should I do?
Old Jul 6, 2004 | 01:38 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Jsut unscrew it. Nothing too hard about taking it off. If you suspect its dirty then disassemble and clean it and reinstall.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
greenyone
Sep 2, 2015 03:39 PM
