Cheap replacement injectors...
Old Jul 14, 2004 | 10:35 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
I think one of my injectors may be bad. I think it is making a ticking noise. Where is the cheapest place to get a replacement? I will be pulling this motor out within a year or two, so a used injector would be OK too.
Also, I know I can get a TBI from a 350 on E-bay that already has injectors in it. Would bolting this 350 TBI onto my 305 help the performance any? I already have an open element w/ K&N Filter, Edelbrock headers, and a Flowmaster cat=back.
Old Jul 14, 2004 | 10:37 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Cheap replacement injectors...
Originally posted by JerseyMark
Hey everyone,
Your best bet is to get a used injector out of a junk yard. look for ther ones that have the white and green on the top. The 350 TBI units are the exact same as the one you have on your 305 but it has larger injectors. Your stock unit will suffice until you have a nice set of heads and a health cam.
Old Jul 14, 2004 | 10:46 PM
JerseyMark's Avatar
Engine: 96 LT1
Thanks... Thats what I will do. I will just get an injector from the scrap yard... And skip the 350 TBI
Old Jul 14, 2004 | 10:50 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I'd say check the spray pattern of your injector first. These injectors tick, loud sometimes, that's just what they do. If its only ticking and you can see a good cone shaped spray out of them I wouldn't bother replacing the injector.
Old Jul 14, 2004 | 11:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Bron brings up a good point I forgot to mention. Also, double check that one of the two prongs on top of the injector is not broken. I had a broekn prong that took me forever to diagnose because I didn't look hard enough. I have no idea how it broke but it did and the injector went bazerk.
Old Jul 15, 2004 | 08:50 AM
JerseyMark's Avatar
Engine: 96 LT1
But its SOOOOO loud. I have headers, a flowmaster and an open element air cleaner on the car and when the trans shifts into 3rd or 4th at low throttle.. All you can hear is this loud sound from the engine compartment. It almost sounds like one of my headers is leaking
Old Jul 15, 2004 | 09:11 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Check for a hedder leak. A ticking sound is usually an exhaust leak.
evilstuie
Apr 14, 2016 08:52 PM
dutch930
Sep 11, 2015 06:58 AM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Leggman1
Aug 6, 2015 04:15 AM
