Vortec
Car: 91' Camaro RS
Engine: LO3 305
Transmission: Built 700R-4
Vortec
i am fairly new at engine overhauls, and i was told that this was a good place for finding info on vortec upgrades/conversions. i have a 350 TBI in my 89 truck. i would like some help from anyone who could possibly give advise. i know its not a camaro but, i am trying to buy one! i just cant find one thats good enough.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Welcome aboard
Vortec longblock wouldnt be a bad upgrade, nor would the heads.
The engine in your truck is an LO5. The shortblock is fine but the heads and cam arnt real good but thats usually not the first place to start. Some good things to do for starters would be exaust mods. See about getting a full aftermarket exaust for your truck. Preferably 3 in. but Im not sure what is and isnt available for your vehicle. Youll have to poke around a bit and see who carries headers and cat-backs.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The Vortec block (and engine in general) is a good platform to build off of. I have a Vortec block. 4 bolt mains, 1 piece rear seal, factory roller cam. However, the block you have now may be just that as well. So it's a toss up.
As for the swirlie ports you have now versus the Vortec heads, there is very little comparison. Vortecs hands down.
As for advice, what is it you wish to know about your 350 TBI, the 350 Vortec, or anything in between? What is it you want out of the engine? What do you want the truck to do (or be able to do)?
Car: 91' Camaro RS
Engine: LO3 305
well i would really like to know what (if anything) i have to do to my TBI. do i upgrade it? or keep it the stock? i am a fan of CHP mag. and i know that they went through alot of trouble with the TBI and i was wondering if i might hit some of the same roadblocks. really in the end i would like my truck to just have that extra power that it deserves so that when i go down to the tracks for high school drags i show all the ricers the true power of a small-block chevy.
Thank you guys for all the help!!!!!!
Car: 88 Camaro SC
Engine: SFI'd 350
Some of the basics to address are...
Exaust: The stock exaust will really put a lid on things. You need to upgrade the entire exaust from the heads to the back of the truck so that more power can be supported.
Fuel: Its a good idea to replace the stock pump with something that can pump a decent volume of fuel and supply fuel pressures over stock. This will come in handy if you really decide to push the fuel system, and its generally not a bad idea to replace the stock pump since they jsut plain suck. Walbro pumps are popular.
Trans/drivetrain: Theres not too much to be done there initially. If you have an auto then maybe a better TC with a stall thats better matched to a new engine combo and a shift kit. If you dont have 4WD you can put better gears and possibly a posi unit if the rear didnt have one to begin with.
If youll be doing any sort of modding, youll want to get prom burning equipment. Its a necessity with EFI, jsut like a carb it needs to be tuned as well. There are low buck burners available as well as freeware so theres not much cost involved if you just want basic functionality.
After that you can swap out the stock heads and cam to something thatll be more condusive to making power. You can also get a larger tbi with high pph injectors, a good intake, nice aircleaner, etc. You definatly need to do the basics first, though. You cant build a house without a foundation.
Car: 91' Camaro RS
Engine: LO3 305
thanks for the help. i am going to look into all of this. now i would just like tio know will it be worth it? and is it really difficult?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Chas91Z28
Oct 22, 2015 10:12 AM
monte87cortez
Sep 26, 2015 08:10 PM
