switch TPI l98 to TBI l98
Will the TBI intake for an L05 fit on the l98 iron heads that came with the l98 tpi ?Do I need to get heads, intake ported ?Should I get the edlebrock TBI intake ? will this give me a good daily driver combo ? all comments and suggetions welcome ( cam. exhaust, 454 tbi vs 350 tbi, all welcome.
C
C
Originally posted by Stekman
Why do you want to convert TPI to TBI?
C
Everything will bolt up to the l98 just as it did on the l05. If you do nothing else to the engine and keep it stock you should be ok. Might have to adjust the fp a little. If you have a way to data log once the engine is in and running, you will know how much tuning if any you will have to do.
Steve
Steve
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The L98 shortblock is a nice match for TBI. You will have much better heads and a much nicer cam. Everything will bolt right up as steve mentioned. You may want to look into a little chip work to take advantage of everything.
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
