Crane Quick Flow Power Spacer
Old Jul 18, 2004 | 11:03 PM
steve8586iroc's Avatar
Just thought you might want to look at it, I believe it hasn't be on the market to long. Look here.
Steve
Old Jul 19, 2004 | 02:32 PM
Ronny's Avatar
i see diff machined swirlies in the bore from different manufacturer's . suppose they(swirlies) work? mine is just a round hole. oh well. those groves prob worth 20 HP(at least).
Old Jul 19, 2004 | 04:12 PM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
There is no such thing as power that comes from a TB spacer.
Old Jul 19, 2004 | 05:38 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
actually I think there can be some that comes from a spacer
if you look at hiemholtz resonater I think it is called it shows a little bit as t owhy something like that can cause a little power increase
granted nothing major but little help
as far as the little grovs
I call BS on that helping much if any
Old Jul 19, 2004 | 10:22 PM
I wasn't interested in buying one but I'd like to some dyno comparisons between the different ones on the market. You know, do they really work, which one works best, is it worth the money? That kind of comparison. Maybe CarCraft can do one on Elwood the 350 tbi truck that they just did. Say start with a comparison of tb spacers then different intakes then a 454tb on a single plane intake with some good chip tuning of course. Would be interesting to see what they could do.
Steve
Old Jul 19, 2004 | 10:52 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
My dad put the helix tower or whatever on his truck awhiel back. From my experiance with spacers you really see no gain in hp but in torque. WE definately got a few more ftlbs of torque off the trucks one.
Old Jul 19, 2004 | 11:21 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Yeah, I agree. I used a 2" spacer, and it fit fine. The SOTP feel was there, though not amazing, it felt faster too cuz the car responed a lot more due to the fact that the throttle cable was tighter and more sensitive to pressure. However, on a L03, I honestly felt nothing more up top. It should increase power, since it's a wet manifold system, more area for blending of the air and fuel, blah blah blah, but I'd like to see a company put out actual dyno results from just a TB spacer swap.
Old Jul 20, 2004 | 10:11 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
TBI spacers,
this has come up lots before. These will make your motor feel more responsive (powerfull) due to the increased intake velocity through the bores. But they can't increase WOT power.
Old Jul 20, 2004 | 10:14 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
https://www.thirdgen.org/techbb2/sho...ht=carb+spacer
Old Jul 21, 2004 | 04:01 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Originally posted by Low C1500
TBI spacers,
increased intake velocity can increase WOT power
but the changes can be done through one of two different things
if you use an open space then you just increased plenum volume which would help out a little more on the upper end
though with the closed spacer not sure on that one
least if you are looking at the whole intake charge tuning with the helmholtz shiz
Old Jul 21, 2004 | 04:31 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Anyone who knows GM tbi's, knows that there restrictive, so at WOT these spacers just add to the restrictive bores, thus creating a larger pressure drop into the intake.
Old Jul 25, 2004 | 02:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Spacers for TBI systems do not work as effetively as they do for carbs. The only difference I saw when I put my .5" spacer on was a lighter wallet and a modified throttle bracket. They do increase the plenum volume a touch that can make your car "feel faster" off throttle, but once the engine is at WOT and under 100% load there will be no difference. The only reason why I still run mine is because I am too lazy to spend another 20 bucks on an open element that will clear my disy.
customblackbird
Aug 15, 2021 10:16 PM
lakeffect2
Aug 23, 2015 08:44 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
