Tbi Stb
Old Jul 29, 2004 | 04:46 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Tbi Stb
I'm looking at the eldlebrock strut tower brace for TBI cars. Has anyone had any trouble with this part? Do you need to drill holes to install this? Did it make a noticeable improvement in your handling? I know Shifty has one and if nothing else it does look nice.
Old Jul 29, 2004 | 04:58 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I have nothing but good to say about it.
You do have to drill 6 holes to install.
(sorry no pics witht he new intake/ect on the engine)
Old Jul 29, 2004 | 06:43 PM
Car: 1990 Formula
Glad to hear it cause I ordered one
Old Jul 29, 2004 | 06:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yup, 6 holes is all you need to drill and there are 8 bolts all together. You only need one drill bit, a socket and an allen wrench. The only thing I do not like about it is the poor quality of the powder coat. However, it absilutely performs awesome.
Old Jul 29, 2004 | 07:58 PM
Car: 1990 Formula
Awesome, I just love cars that can handle around the curves, my engine bay isn't much to look at anyway.
Old Aug 2, 2004 | 01:07 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
How much of noticable difference did the STB make? Is it really worth it?
Old Aug 2, 2004 | 01:21 PM
Dewey316's Avatar
Car: 1990 Camaro RS
yes, everyting you can do to stiffen the chasis, and control strut deflection and movement helps.
Old Aug 2, 2004 | 01:28 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Does it improve ride quality? And help eliminate squeaks and raddles?
Old Aug 2, 2004 | 01:29 PM
Car: 1990 Formula
Do you guys think it is worth adding a wonderbar as well? As far as I can tell they serve the same function.
Old Aug 2, 2004 | 01:33 PM
Dewey316's Avatar
Car: 1990 Camaro RS
they serve completly diffrent purposes. The STB is to keep the upper mount equidistant from each other, so teh camber curve is matched between the wheels.
The wonderbar is to re-enforce the frame rail, where the steering box attaches, it is known to have issues with craking.
Yes, both are worth it, and both are smart upgrades.
Old Aug 2, 2004 | 01:49 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Ditto. The front end of these cars is one big floppy box. We all know how well a cardboard box holds together without the bottom. You should always get sub frame connectors first. Then look into a STB.
Old Aug 2, 2004 | 02:19 PM
Car: 1990 Formula
I had subframe connectors welded in about a month ago, thats what started my suspension addiction.
Old Aug 2, 2004 | 02:24 PM
Dewey316's Avatar
Car: 1990 Camaro RS
just wait until you keep a calculator in the garage, and start thinking about angles and geometry ALL the time.
Old Aug 2, 2004 | 02:29 PM
Car: 1990 Formula
Are there any other suspension products you would recommend picking up? I've thought about lowering my car but I'm trying to keep a stock look on the outside.
Old Aug 2, 2004 | 02:31 PM
Dewey316's Avatar
Car: 1990 Camaro RS
don't get me started, you will be thousands of dollars poorer. i have a LONG list.
(see sig) and that is not everything, and i have several more things in the works.
Old Aug 3, 2004 | 09:09 PM
Car: 1990 Formula
Okay guys I got my STB and I've got some problems. First off it doesn't want to line up like I think it should. The two pieces that sit on the fender well don't want to sit flat and second my drill seems to be powerless against my car. Any suggestions?
Old Aug 3, 2004 | 09:15 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would use a punch to get the hole started. Keep trying to posistion it in a neutral place. It sits on the outward edge of the firewall lip. I would put the whol thing together and lay it in place and use a marker to mask where it fits best. It takes a little patience and some good "ol' eye ballin' ", but you will get it. Don't worry if the two peices do not lay completely flat on the lip. It will bolt down just fine.
Old Aug 3, 2004 | 09:42 PM
Car: 1990 Formula
My friend used a hammer and screwdriver to start a hole, made me cringe everytime he swung. Did you have trouble getting the drill straight with the hood on or is it just me?
Old Aug 3, 2004 | 10:24 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It is tricky but you can get it. I think mine was at a slight angle when I did it with the side of the drill pressed against the inside lip of the back of the hood. A little angle won't hurt anyhting.
Old Aug 4, 2004 | 07:28 AM
Car: 1990 Formula
I'm gonna give it another shot after work today, for some reason I thought this was going to be an easy install. Did you have to jack up the car to tighten the nuts on the bolts for the side mounts?
Old Aug 4, 2004 | 07:39 AM
Dewey316's Avatar
Car: 1990 Camaro RS
nope, i can access them just fine with the car sitting.
Old Aug 4, 2004 | 08:28 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Same here. I just reach under the fender well there and get a wrench on the bolts. I thighten from up top.
Old Aug 4, 2004 | 08:38 AM
Car: 1990 Formula
Cool, looks like all that wheel gap will come in handy for the first and probably last time ever.
Old Aug 4, 2004 | 04:43 PM
DM91RS's Avatar
Car: 91 RS
Something that might help you guys if you are not already doing so is to mark the center of the hole and drill a pilot hole with something small like a 1/8" dia. bit and step it up from there until you have the size that you want. With sharp bits and a good drill that strut tower dones not have a chance.
Later Darrell
Old Aug 4, 2004 | 04:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Later Darrell
This what I did for the strut area. Just make sure your drill bit is small or you will hear a suspicious hissing sound
Old Aug 4, 2004 | 06:59 PM
Car: 1990 Formula
Okay heres the latest, I finally got the holes drilled through on the firewall lip, but it won't sit right if I put the stb over the lip I have to put it under, don't think it should matter except now I'm having a hell of a time getting the nuts on the bolts. On a side note I want to kill this thing, I really do...were it alive I would smack it with my hammer...
Anyway, delay of game has been called due to thunderstorms...
Old Aug 5, 2004 | 09:59 PM
Car: 1990 Formula
Woohoo, look at me and my bad self, I got it in after only 3 rounds of fighting with it. Kinda makes me wish I could drive her...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
