choke and puke
Old Jul 30, 2004 | 10:56 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
choke and puke
Ok I know I need a custom prom it would be nice I could get my laptop to read my car again has not worked since February
Anyway here is the deal I have an 86 L69 305 HO crate engine
Lunati cam .455 intake .483 exhaust 205- 215 .50 duration major ported heads, 454 tbi unit 55lbs injectors installed on ported 350-tbi truck intake
Headman shorty headers ran pretty good with stock tune low 14 sec quarters at 96 mph
I changed the intake manifold to a weiand 7547 single plane blocked the exhaust crossover in the heads
Now it idles ok normal driving is good, however when I get on it
It will take off great than load up, and misfire about 2500- 3500
Than haul *** to 6000. Now here is the weird part if I drive it HARD for 15 -20 min it runs F**n great!
Should I pull the intake and open the exhaust crossovers or just plan on heavy prom tuning
I am thinking of just putting a carb on it and being done with it
Old Jul 30, 2004 | 11:37 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you want to stay with TBI you need heavy PROM tuning.
Old Jul 31, 2004 | 12:47 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Maybe a fuel regulator will help out. The TDS one may be your answer but like everyone says chip burning is essential, just not for me right now.
Old Jul 31, 2004 | 03:31 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
That's funny that you posted this now. I just did an intake and header install on my engine. I'm using the Holley TBI manifold with EGR blocked off. I get the same bogging at the same RPM level you're saying. It just falls on its face at that range. I just figured I needed chip tuning that maybe its picking up some knock in that range and pulling a bunch of timing out. We'll see when I finally get the tuning stuff.
Old Jul 31, 2004 | 08:21 AM
MY-92-RS's Avatar
I have been without an EGR for years, I do have an adjustable fuel regulator; Holley 255 fuel pump seems to make no difference where pressure is set, I guess something about changing intake manifolds sent our engine calibrations over the edge-- I am thinking of pulling the intake back up today {It has a slight oil leak from the rear seal}
I am going to open up the exhaust cross over maybe fuel is pooling on bottom of intake when engine is hot problem mostly goes away
I wish I could still data log and see what the heck the engine is doing
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
