?'s on fuel pressure guage adapters..need help
Car: so many projects to little time
Engine: 350 tbi
i have a holley tbi unit i am fixing to use (just got from jegs). the only thing i am waiting on is i want to put a fpq on the feed line to the tbi. i have found the fitting through earls performance plumbing but i dont know the size. -6,-8 an, what does that mean 1/4,3/8 npt. what does an and npt mean and what size do i need. how can i tell the size and so on. i know it needs to be male on one side and female on the other. thanx ahead of time guys.....
i have the part # at home if you email me. i used aeroquip fittings however. it actually has an o ring on the end that (male) enters the TB. i believe the size hose i used was 6 AN. not sure what the pipe size was(male end). i took TB to speed shiop(aero distributor) and they fixed me up nicely with all fittings needed.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
what would be really nice is a adaptor with a shrader valve, so you can attach a gauge that you can see while driving.
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
So how difficult would it be to make one like that? Anybody have access to the materials? I bet they would sell like hotcackes! I know I'd buy one, for sure.
Just like an extension fitting, but with a schrader valve installed in the side. Something like that, Dewey?
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I removed the diagnostic gauge and screwed the hose into the diaphragm that comes with AutoMeter's isolated fuel gauge.
Don't have time to resource the numbers right now, so if someone else doesn't jump in with the numbers, I'll find 'em.
Car: 89 Firebird
Engine: L05 350 TBI
I think I found it
http://www.actron.com/cgi-bin/web_st...id=268682_5745
And at autozone it's cheaper
http://www.autozone.com/servlet/UiBr...7C%7EEA%7C%7EB
Car: 89 Firebird
Engine: L05 350 TBI
va454,
BTW, what model Autometer gauge do you have? I'd like to setup a gauge in the car also. I have been looking, but the only ones I see go to like 15psi.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Originally posted by jconrad
va454,
va454,
http://store.summitracing.com/partde...art=ATM%2D3313
However, I've exceeded the 15 psi limit of the gauge a little, so I installed this:
http://store.summitracing.com/partde...art=ATM%2D3312
However, its less accurate than should be.
I need to get this:
http://store.summitracing.com/partde...art=ATM%2D5282
Hope that helps
Car: 91 RS
Here's a pic where I ran mine from. One is under the hood which you can see and the sensor runs to an electric guage inside.
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
DM91RS could you take a closer picture of your fuel prssure gauge setup. I've been all over trying to find a T fitting to mount it the same way you are but I can't find a T fitting to go inbetween the hard and soft line. Could you tell me what you used.
Car: 91 RS
I was subscribed to this thread and would not have known except for e-mail....anyway the t-fitting with barbed ends came from Summit racing. Part number or size does not come to mind after 4 years. Hope the fuzy pic helps. The actual fitting is the silver part. I have a nipple and another t-fitting plumbed in to allow a guage under the hood and an electrical sensor for the guage in the car.
Hmm not exatly what I was hopin to see but it helps. Have you had any problems with leaks from having that kind of setup on the high pressure line?
I was hopin to find a T fitting that would go inline with the factory setup without having to cut anything. The picture will show better...
Car: 91 RS
No leaks after four years of having all that shet hanging there. Its just an inline t with barbed fittings and a 1/8 NPT tapped hole in the middle. I did not find anything else when I was looking back then. Not that there isn't something to be found. I didn't want to cut it either but have had no problems
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
