TBI swap / now it dies
Old Aug 3, 2004 | 04:07 PM
travelinman's Avatar
Car: 89 RS, 91 GTA
Engine: lo5, lb9
Transmission: t5, a4
Ok, I've looked and can't seem to find any answers with a search so maybe someone has some ideas. I've got an 89 camaro with a t5. I swapped in an L98 longblock about 6 months ago and I've had this problem since. When the car gets warmed up and i'm cruising along in 5th gear and hit the brakes and go to downshift at the same time the car dies. I've replaced plugs, cap, rotor, wires, CTS, IAC, injectors, knock sensor, and spark module along with a chip from TBIchips. Other than this problem the car runs great and it doesn't do it if I only hit the clutch or the brakes, just when I hit both. Any ideas?
thanks,
Jeremy
Old Aug 3, 2004 | 05:40 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I would check your timing.
92camaroJoe
Jul 29, 2023 07:57 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
