can tbi injectors be installed backwards?
Car: 1989 Firebird Formula
Engine: 305TBI
I see the wires are different colors but the terminals on the injectors are the same orange. Is it possible to get them mixed up if you pull them out trying to clean them and for get which wire went to which side? Let me know, ive got one injector driping fuel, the other not spraying at all.
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
As far as the wiring goes, there's no polarity on the individual injectors. To the electronics, they're just a coil that looks the same from either end. ASSuming there isn't a short or open in the wires going to the injectors *and* the connectors are on securely, your problem isn't with the connectors......
