Code 32, sometimes, and surging idle..
Old Aug 9, 2004 | 12:12 PM
89_305TransAm's Avatar
Car: '89 Firebird Trans Am WS6
Engine: 305 TBI (L03)
Hey guys.
Maybe you guys can help me out with this.
My car is a 89 TA with a 305 TBI. all emissions on the car are removed, AC removed as well. Sometimes on long highway drives ill get a code 32, which i understand is EGR? On long drives though ill see it come on, last for a minute or so then the SES light will go off! Lately though im getting this weird problem. If im stopped and on the breaks, the car will rev itself and try to move. Scary if im lightly on the breaks behind a car at a light or something. I have not seen this happen while it was in park, yet anyway. It may also be happening while driving, as in when im on the gas already it may give it some more gas by itself? Why is this happening?
Also, im leaving for wildwood(down the shore, wayyyyyyyyy down in NJ) the 23rd, its basicly a nice long drive in OD down the parkway but do you think my car is going to be affected by this? I plan to change the oil before i go and the car recently had a tuneb up(before this started) so i think i should be fine.e.
any suggestions?
Old Aug 9, 2004 | 12:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The only way to really remove the EGR is to dissable it by setting it to come on at higher speeds in the chip. If not the car could be running lean whenever the EGR should be working. That could be causing your surge.
Old Aug 9, 2004 | 01:48 PM
well i didnt remove the EGR, i guess by saying all emissions i was wrong. I ment all the aIR, the air pump the tubes the cat, all that stuff.basicly the "i can see my pass side valve cover" mod
Old Aug 9, 2004 | 02:25 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
That is a good way of putting it I would suspect a sticking EGR valve. I would hood a vacuum source on it to see if it is still working. A code 32 on highway driving will happen to every GM vehicle at some point.
Old Aug 9, 2004 | 02:28 PM
In your opinion, think it would drasticly effect the ride down the shore? I really dont but what do you think?
And i shoudl take a vac line from elsewere and put it there or what?
Old Aug 9, 2004 | 04:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It can drastically effect the way the car drives if it hangs open for to long. All of those residual gasses aren't ideal for power but serve their purposes when intended. I haven't checked my EGR valve in years so I cannot remember the read-outs off the top of my head. Let me check on that.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
