Idle problem
Car: 89 RS
Engine: 383
Axle/Gears: 9 bolt 2.77
Idle problem
I am having a little idle problem... erratic 750-900rpms. I have a 283 .040 over tq convertor is a tad over stock. I am running factory TBI injection with match porting. Headers that forot to use the EGR system!! Would a custom chip help this out? More timing? Total advance is 34 degrees. There is tons of power! Not lacking in this area at all. I just don't want to start taking wild stabs in the dark here!
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You need chip work. You do not have the same displacment as stock nor does that motor use the same fuel and spark values of the 305.
Car: 89 RS
Engine: 383
chip work it is!!! i was afraid of that!!! no one that i know of had a ability to help me in this area where i am at!!! Thanks for the point in the right direction!!!!!
