too much cam for 305??
Old Aug 20, 2004 | 03:56 PM
Project-ROC's Avatar
Car: 86IROC/91RS
Engine: 305tpi/305tbi
Transmission: 700r4's
I was reading up on the LT1 cam and noticed that a couple members with slightly modded 305's wish they would have gone with something a bit bigger than the LT1 cam...So I was looking for some expert opinions on whether a crane 226/234 cam 114LSA .458/.473 lift would be too much cam? As of right now the motor is stock 305tbi...however I would port the stock heads my self, change out valve springs/seals and put a performance tbi intake...along with a full exhaust from headers to cat-back.
Or would a wise man save this cam for a 350 with the same set-up? I think I know the answer but I would just like to hear someone elses thoughts....BTW tuning is not a problem - I'll burn a chip until I get it right...
Old Aug 20, 2004 | 04:12 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i dont think that cam is to big for a 305 depending on what your plans are. If you have headers and exhaust and have ported some 305 tpi heads instead of trying to port the tbi heads then providing you can get help with chip tunning, I think thats doable. you would definily notice some good throttle response.
Old Aug 20, 2004 | 05:07 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
I would personally go for a cam with a lot higher lift and less duration.
Old Aug 20, 2004 | 08:49 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
unless you really want to do TONS of tuning, and plan to spin to 8k, it is too much cam.
for reference i'm running 206/216 duration, and it has introduced some interesting tuning issues.
Old Aug 20, 2004 | 10:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Ditto that the cam is pretty steep for a 305. You would also need head work since the lift is a bit much for stock castings. You would have to have seat work down to most GM heads that you would go with.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
